danglingparticiples
- May 2, 2012
- 7
I have a 1995 Chris Craft Concept 19. It has a Volvo Penta/OMC 5.0 that is based on the Ford 302 block. Model 50FAPHUE with a SX drive.
Last year I pulled the out drive and replaced all of the seals while replacing the bellows and gimble. I did not however seperate the upper and lower unit. I have noticed that I have some gear oil leaking from a small weep hole on the lower unit.
My gear oil is milky so i know that I have water intrusion.
are there some seals in between the upper and lower unit that may be leaking.
Thanks
Bob
Thanks
Bob
