cuttlefish310
- Jan 18, 2013
- 3
It's a 1994 model, low hours and recently completely stopped producing a spark.
OK, did all the amateurish things, no luck so started down the well known "remove and replace" procedure that invariably proves nothing other than reduce your bank roll.
This included:
1. New spark plugs (gaps fine)
2. New plug leads (not fibre optics)
3. New expensive coil
4. Two new marine batteries
5. Checked and replaced numerous wires with broken insulation and one rotted out battery cable
6. New ignition module - the epoxy sealed type with all the gizmos in the module
7. New distributor cap - in case of cracked cap on old one
8. 12v wire connected from battery to positive on coil, coil negative earthed - nothing
Employed two independant marine Sparkies who, after six hours troubleshooting and $500 later, found nothing!
Checks performed showed:
1. 10v ex coil when cranking the engine
2. By passed ignition switch - nothing
3. By passed coil wiring - nothing
4. By passed everything else - so they said - nothing
5. Not a sign of a spark ever, anywhere. This is third coil so unlikely it is the problem
6. Confirmed rotor in Dizzy is spinning during cranking
7. Every single system shows a good, healthy 12.5V but ain't no sign of a spark anywhere
One item that is always there is a really hot coil. Even with the motor shut down, the coil can hardly be touched when the engine is static - wonder why this is?
Got us all beat!
Any advice appreciated.
This included:
Got us all beat!
