Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Winterizing a 1981 omc 3.8 and omc stringer 800
  • Winterizing a 1981 omc 3.8 and omc stringer 800
    I have a new to me boat that I need to winterize. I need to find the locations of all the drain points. I have only ever owned mercruisers. Anything special with the omc I should know about. I downloaded the manual in the adults only section, but it was very vague about locations.
    This is in a 1981 sea ray v197.
    Any help would be great. Thanks
    Click image for larger version
    sigpic
    1989 suncruiser 24 ft pontoon. 1979 johnson 70hp 3 cylinder
    Re: Winterizing a 1981 omc 3.8 and omc stringer 800
    there's 4 drains (+1 more if you have power steering)
    1 on each manifold
    one on each side of the block, just astern of the selectrim mounts- the starboard side between the fuel pump and starter is the toughest to get
    remove the plugs and poke wire in all holes.
    then you can take either end of the u shaped water pump hose off and tip it to drain
    Baba-buoy.
    • #3
      Thanks. What about the outdrive. Does anybody know where to find the factory service manuals.
      sigpic
      • #4
        Check here on I-Boats first and if no luck try Ken Cook in Milwaukee WI.
        • #5
          change the gear lube in all 3 compartments
          change the clutch compartment lube
          store the drive in the full down position so water does not run in the prop and crack the impeller housing
          Baba-buoy.
          • #6
            Thanks guys. I am working on it this week. want to make sure I get all the water out.
            sigpic
            • #7
              http://forums.iboats.com/showthread.php?t=178695
              Baba-buoy.
              • #8
                Okay I was looking over the motor and found a exterior crack in the manifold on the starboard side. Not sure if it would be worth trying to weld or not. I found a used pair for 100 dollars. Haven't been able to look at them yet they are from a 1984 motor. Would they fit
                sigpic
                • #9
                  1981-1985 3.8's all used the same manifolds.
                  Baba-buoy.
