I have done a lot of work to this boat over the past year and its finally in the water! After replacing the cylinder heads I only timed the engine by ear, and I learned yesterday its way off! It has one of those pertronix electronic kits and at idle the timing was off the scale quite a bit on the BTDC side... I turned the distributor until it was running right at TDC and it would then go up to about 8 BTDC at about 2k rpms.
I'm not exactly sure if this is right for a couple reasons. The last time I took the boat out the motor had a slight tap when running WOT and I thought the timing might be the cause since I have gone over everything else. I have new heads, and valves as well as gaskets, I have 175-180 psi in every cylinder and the motor oil is as clean now as when I changed it a few weeks ago. Its running great! When I changed the timing it brought the idle way down so far I had to adjust the idle screw on the carb, and it does sound real good... All I can do is wait until I take it back out tomorrow.
Does it sound like I have it adjusted properly? I do have SELOC book, but I didn't see the actually adjustment in there...
Thank you,
Thank you,
