02gixxersix
- Aug 4, 2012
- 3
I hate that this has to be my first post. I just bought my first boat, a 1986 Baja Sport 200. It has a 350 and cone-clutch King Cobra outdrive so not original power. I am told by a marine part store rep that based on the model number on the drive it is from 1991. Anyway, I took the boat out once and ended up with a ton of water in the outdrive oil. I bought a seal kit and resealed the lower unit, but cannot get the bearing housing torqued. I also can't find the number for the removal tool anywhere. I bought what I thought was the right tool and it turns out it is the spanner for the driveshaft. The part number in the crappy manual that I have is 914684 but when I google it I can tell that it definitely won't work. There are 4 little slots for the adapter to mate to the bearing housing and obviously it has to slide over the prop shaft. Any help will be greatly appreciated.
