Hello,
I apologize if I'm posting this wrong, I'm just getting started out on this forum.
I have a 1987 Chaparal with an OMC cobra outdrive and 4.3L GM engine. I guess they original came with a point ignition system and at some point a previous owner updated it to electronic. The other day I was headed out to do some fishing and it stalled out, and then got me back to the ramp running on maybe half the cylinders. I got home and pulled the distributor cap to find that all of the magnets around the rotor flew apart... They were originally taped down with a piece of green tape.
I'm having an awful time trying to track down this replacement part they call a "magnetic assembly" or something to that effect. Its meant to slip over the cam and act as a spacer between the new pickup plate and the old rotor.
Questions are these... Can this be purchased? If it can't what options do I have for buying a used distributor? I went to the junk yard but quickly found that the 1987 4.3 gm truck had a completely different setup... Does anyone know if I can get a one wire HEI distributor that will fit and work properly?
Thank you,
Thank you,
