georgerbare
- Aug 21, 2012
- 11
Is there a better way to remove the bearing races for the ball gear shaft from the IM housing? I've been slide hammering for hours and have only moved the first bearing race a 1/4".
if you backed it up to any welding shop, they'd probably weld-shrink it out for $40 or soWelding idea is interesting, unforunatley I don't have a MIG set-up.
that is the tin part of what remains of the inner oil seal - it'll just pry out with a screwdriver once the bearing is outwhat's that behind it?
