The gears sets on my 1996 Volvo SX outdrive are gone. Forward and reverse are not too bad, but the main drive pinion is completely gone; chips everywhere. I thought I would weld it up and re-cut it, but I can't get it out. Somethings holding the vertical shaft so I can't get to the torx to get the pinion out.
I need to replace the drive, but do not know how to match them when shopping. Can you lend advice on what to look for and what to ask? Serial numbers, models numbers, gear ratios, etc...
Thank you,
J
Thank you,
J
