I have an 87 bayliner capri with a 3.0 My issue is that once the engine warms up it doesn't idle smooth at all and usually dies if you don't play with the throttle and also starts hard when hot, you have to play with the throttle to help it get going. The previous owner had the carb replaced with a seirra brand carb, not sure why though. I have tried adjusting the idle mixture screws in and out along with the idle speed screw and thought I had it really close last summer but the first time out this year was pretty bad. Also once you get going it runs really good at all rpm ranges. Only maintenace I have done is spark plugs, checked timing wich was really close, fluids. I'm leaning towards a carb issue but wondered what you guys thought?
