Hey guys heres my problem. About 2 months ago my low pressure fuel pump went out so I went ahead and replaced both the low pressure and high pressure pumps. Took the boat out for the first time about 3 weeks ago and within 10 minutes it was running hot. Turned around immediately and found that the thermostat was stuck closed. I replaced the thermostat and went right back out and suddenly the boat will not go!!!! It idles fine and if I very gently ease into the throttle I can get it to go but not enough to get on plane. If try to acclerate normally it bogs down and will not rev. Even when it was running hot its was still running perfectly, it would go right up on plane and not skip a beat! So over the last 3 weeks I've been going thru my Volvo Penta manual and searching the web for different ideas and here is a list of what i've done/ replaced:
New IAC valve ( i know this has no affect on acceleration but I replaced it as part of rebuilding the TBI)
New MAP sensor
New TPS sensor
New water fuel seperator
Completely rebuilt TBI
New Cap and Rotor
New Spark plugs
New Ignition module
New Ignition Coil
New water temp sensor
The fuel pressure holds steady at 14 psi
The compression is 165 to 180 on all cylinders
Ive tried running it on a seperate fuel tank with fresh fuel
IT IS NOT GOING INTO SAFE MODE!!! It wont even rev to 2500 rpm unless I gently apply throttle and that is if its on the trailer under no load. Under load it is basically impossible to make it accellerate. As soon as I give it any kind of throttle it immediately bogs down and wants to die. I dont have a scanner to look up any codes. I know I need to do that but I will probably just take it somewhere to have it scanned. I'm thinking that the ECM is probably bad I just wanted to post on here to see if anyone has any other ideas. Thanks in advance for any help.
New MAP sensor
New TPS sensor
New Cap and Rotor
New Spark plugs
New Ignition module
New Ignition Coil
