Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Transom seal replacement
  • Transom seal replacement
    I am going to be replacing my OMC transom seal tomorrow. What kind of sealent should I use between the rubber and transom?
    Larry E
    Re: Transom seal replacement
    3M 4200 or 5200 should work just fine.
    1969 Lonestar Medallion restoration
    1972 Glastron GT-160 restoration
    1973 Silverline Grand Bahama restoration
    1991 Galaxie 19' 4.3 Mercruiser
    2007 F150 4x4 Supercrew
    A boat is just a big hull in the water you throw money into.
    • #3
      I am told that the 5200 is very permanent in that it is more then difficult to remove later on. Is the 4200 like that?
      • #4
        Ayuh,... 4200 is like 5200, only removable...
        • #5
          Which would be better?
          • #6
            Ayuh,... Define Better....
            • #7
              I like the Permatex Copper, mainly because my boat is orangy red. Most boat builders used no sealant. Any RTV fine. I would think 4200 probably better than 5200. You don't need bonding, the clamp holds it.
              Baba-buoy.
              • #8
                Easier to apply. The 5200 which I have seems to not be very easy to move around. And should I be able to remove it down the road in case I would need to replace the seal again?
                • #9
                  i've used Silicon RTV with no problems.
                  ~ Allan
                  Be careful in what you wish for....You might get it.
                  Baretta Rebuild
                  Complete Baretta Picture Set
                  • #10
                    That is great advice. My boat is orangy red also so Permatex Copper it is...Click image for larger version
Name:	Trailer restoration.jpg
                    Back to Top
