Hi there,
this is my very first post. I 'm having some issues with my 5.8L motor. Here' s the story.
After 40 minutes of crusing, it started to stall, but would not die as log as i crusied at idle speed. After a break of three hours, it run fine for about half an hour, until it started again.
Tho above situation happened twice, and before i start changing parts i would like to ask a few things. (i have allready read similar threads and have narrowed the possible problems. (at least i think i have).
1. The motor (1991 584APRRGD) uses a Prestolite BID ignition. I would like to change the coil, but the surface is in bad shape an there is no part number to order, so the first question is, does anybody know which part number should i be looking for?
2. I ' m not quite sure if there is a resistor wire attached to the coil. Does this model work with one?
3. My (ex)mechanic replaced the mechanical pump with an electric one (part number 3858261 ). I can't seem to find any spec. for this. Could it be insuffucient?
Any suggestions?
Any suggestions?
