Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
what to use to clean cooling system on a v 6 used in salt water
  • what to use to clean cooling system on a v 6 used in salt water
    hi ive been told to use caustic soda to clean my cylinder block as it is badly corroded ive stripped engine to do this and block is bare is it a wise thing or is there anything else i can use as ime going to put block in a tank and leave it soak cheers mat
    Re: what to use to clean cooling system on a v 6 used in salt water
    Refer to this link
    Cylinder Head Cleaning: Engine Builder
    http://www.enginebuildermag.com/Arti..._cleaning.aspx
    'All other things being equal, a bigger engine makes more power.'
    1988 Bayliner 2150 Capri with 5.7 litre vortec engine and Cobra drive
    1979 Jem craft Southwind with 460 big block 550 Hp with Panther jet unit
    • #3
      Ayuh,.... A Different used block,..??....
      • #4
        Wouldn't the soda also eat the bores and bearing races, lifter bores, cam bearings?
        When will people learn that impellers require regular
        replacement and are not drive it till it pukes items?
        1984 Regal Medallion 195
        3.8 V-6 with the dreaded
        OMC Stringer Drive.
        2003 Avalanche w/Hypertech
        If it ain't fixable - don't break it!
        • #5
          used caustic in the end done a brilliant job engine block was bare no bearings at all it dissolved all the rust out of cooling system i put it in a plastic 45 gallon drum and mixed 6 kilos of caustic with water then i put a steel pipe into cylinder block and connected it to a compressor so it would bubble causing sirculation left it for 3 days adding boiling water every now and then seemed to make it work better then remmoved it and washed it with a hoze first then pressure washed it with plenty of tfr to get rid of the caustic.
          the block has been powder coated to protect it new liners cam bearings cam crank and oil pump fitted looks realy good ile try and post pic but ime usless at doing computers
          Back to Top
