Stupid question of the day: Although the manual tells me how to do stuff it doesn't explain why.
After removing the transom leg I noticed the bottom bellow was split. No worries I'll replace it, thought I. Then I got thinking as to what function the exhaust bellow provides within the context of my boat. I have a four winns 201 liberator with through the hull exhausts.
Looking at the leg I have the following pipe work:
1.) Drive shaft bellow - protects drive shaft and gimble bearing from water ingress, simple.
2.) Small gear linkage bellow - yep, I understand what that's doing also.
3.) Exhaust Bellow - At first I though this was the conduit for the cold water pumped up from the leg to cool the engine and exhaust which then exits through the hull exhaust swirl chamber. That was until I saw the pipe (below) which looks a much more likely candidate for this function.
4.) Water pipe, similar to car radiator pipe, hmmm - see above.
Can you folks clarify what the exhaust bellow and the other water pipe does on my boat? From other posts I've seen folks say ensure the holes in the exhaust bellow are pointing down. Mine didn't have any holes, just split / perished on the first concertina.
Thanks,
Sp.
Thanks,
Sp.
