I've just replaced the engine in my boat (454 OMC) and I need to set the base timing o 8 or 10 degrees BTDC because when I installed the distributor on the new block, I had to set it at o degrees BTDC. The timing should actually be around 8 degrees BTDC but I need to bypass the module in order to set it. I need to know which wire to disconnect/jumper to bypass the module and set the base timming. I have ordered a service manual and am still waiting for it to arrive. Can anyone out there help me out??<br /><br />Thanks
