I've just replaced the engine in my Chris Craft, 7.4L King Cobra with a rebuilt engine. The timing is currently set at 0 degrees and I need to set it to 8 degrees BTDC. The problem is that I don't know how to reset the base timing (electronic ignition). Is there a wire the I need to unplug or jumper? Do I need a special tool?<br /><br />Thanks,<br /><br />Dave
