dellsboater
- Nov 19, 2010
- 193
What does it mean when OMC trim clicks both up and down, but will not engage trim motor.
1988 OMC Cobra 5.7
1988 OMC Cobra 5.7
http://forums.iboats.com/showthread.php?t=334348Thanks for the help, any one have a picture or diagram of thses and how to jump them? Seems odd they both could go at once, but have seen odder stuff happen!
Update:
I tried to jump the solinoids, The big bolt on top to the one directly below it. I had to take a rubber cover off the top bolt to access it. Nothing happen. I know the top was getting power. I thought I would hear a click, but did not. Assume I did not have to run the trim switch while jumping right?
So, does this suggest it is the trim motor itself?
Also did remove battery and charge. Put back in, same result, trim up or down, just a click from the solinoids....
