Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Reinstalling Cobra Outdrive
  • Reinstalling Cobra Outdrive
    I pulled my outdrive (1989 Cobra on 5.7l) to replace the u-joint bellow and shift cable. While trying to reinstall the outdrive, I ended up chewing up the inside of the new bellow, around the inside of the rim.My questions is, is it OK to still use that bellow (I'm thinking the acutal seal is more to the outside of the lip).Also.. is there a "trick" to getting that dam drive back on?? Everytime I pull it, it takes me 2 hours and three guys to get the u-joint through the bellow.. after that it's fine. Just wondering if anyone had any tips on that.Thanks!!-David
    Re: Reinstalling Cobra Outdrive
    Read here: http://www.iboats.com/cgi-bin/ubb/ul...;f=24;t=010204 This may help some
    • #3
      Hate to say it,but it's a fact of life.These drives can be hard to install.Try using a screwdriver to turn the ujoints as you instal.Also if it engages the splines,try clicking the starter.Usually goes in okay then.Also follow up on the previous posts.Sometimes a walk around the block works.Sometimes they go in so slick you could lose a finger.DHP
      • #4
        put remote in neutral shift drive into a gear as pushing drive forward turn propshaft which in turn will turn "u"joint shaft this helps a lot once "u"joints have cleared bellows drive should just slide on and it should shift back to neutal (be sure)hope this helps
        • #5
          hello I guess I am lucky. they are tight but I have never had a problem with them. I lube the u-joint cross with dishwashing liquid and rotate it with a thin screwdriver while installing. always goes first try. I do however block the skeg up so I am not holding the weight of the drive. I got to old. or they got heavier in later production runs, not sure which
          no tech questions by PM, they wont get answered.
          you have to be trusted by the people that you lie to .
          • #6
            rodbolt,You must be holding your tongue right. Thats the secret you know...
            • #7
              I tried spinning the prop as we pushed it, but the u-joint wasnt clear of the bellow seal yet, and ended up gouging it up on the inside. That suck because it was a brand new bellow. I had to but the old bellow back on, then it went in easier.-Thanks.
              • #8
                My old cobra was a miserable ***** to install.I found this stuff for Caterpillar hydraulic seal installations Cat part # 1U9891. That stuff helped- it's so slippery - dishsoap would certainly be easier to find.
                • #9
                  FYI, OMC later changed the inside I.D. of the bellows by 0.30" to allow EZier installation of the OD (that gave 0.15" more clearence). The bellows, BTW, is really ez to change for those who just have such a time with what they have. MerCruiser should of did it the OMC way! I usually put the drive in gear, and turn the prop to get the u-joint/shaft assembly rotating, that usually helps it slip in past the edge of the opening. And whenever I need to, I just turn off the lights, somethings I do better in the dark!!
                  • #10
                    They did on the Alpha I Gen II's and all the Bravo's
                    Don S.
                    Please, no PM's (Private Messages) regarding boat/engine problems.
                    That is what the forums are for.
                    Only forum/moderator issues will be answered in PM's.
                    • #11
                      Yes, Don, but it's "just a little bit tighter" at the transom end on a merc than on a Cobra. OMC gets the nod!
                      • #12
                        but nothing beats the SX for ease of removal,dissasembly and reinstallation. kinda like v yamahas lower unit R+R.
                        • #13
                          OMC gets the nod!
                          Yer kidding........ESA system that can only be adjusted by those with a thousand years of experience, gear problems because of wrong angle on the shift dogs, shift cable problems ....... went out of buisness, miss one thing and you loose a 3 thousand dollar drive. Yep, that would make me give them the nod over Merc.I'm with rodbolt, Volvo any day over either of them, even in the 60's.
                          Don S.
                          • #14
                            I did not know we were discussing ease of repair or the fact that volvos dont require as much as OMC or merc. the propshaft thing on the SX aside and the lower swivel pin that needs modifiying on commercial drives. but if I was gonna buy something that sticks out the back mine will be volvo.
