Mustang1956
- Jul 16, 2011
- 3
Can someone tell me which of the 3 tabs on the camshaft marker is TDC? I've got the crankshaft at TDC and want to set the timing belt. Don't want to pull the valve cover if I don't have to. Thanks
Stackz - Thanks. I looked at that link before. The picture shows a single pointer for the cam.
This engine has a plastic pointer with 3 tabs for pointers on the cam. I'm assuming it's a 5 and 10 degree shift but the center tab could be 0 also.
I'll try and post a picture this morning once the sun comes up.
did you ever find out what the 3 marks are? I am having the same issue with my 2.3l ford.
