I noticed a crack on the shift upper gear housing plastic cover. My assumption is that water does not belong on the other side of the cracked cover and when I loosened the rear bolts of the cover water did come out.
Anyway, I removed several bolts but find myself stuck at the upper two in this picture.
1. Do I need a special wrench to get at those 3/8 bolts, or should I remove something else to facilitate access?
2. Since this part is NLA, is there another way to repair the crack?
I looked in the OEM manual, Section 11, upper gear housing, and nothing jumps off the page on what to do here.
