Re: Water jacket blown on my 1985 OMC 3.8 Liter V6 - Need a engine block
Got my engine swap over for $764.55 My boat is a Rinker 19 ft open bow mfg 1985.
OK so here I am with a 3.8 ( 1984 I believe ) Chevy engine block and all the parts from my old boat motor. The manifolds miraculously are not cracked.
I start this engine and it purrs like a kitten.
I got my boat up on plane with it the first hundred feet and travel at maybe 30 mph ( 3/4 throttle ) as I approached a no wake area and as I slowed down the boat stalls.
Worried, I put it in Neutral and it starts right up and I maneuver into anchor spot and take a nice swim.
To leave, I start out slow, no wake, and make it back to the launch at a bit slower speed and it doesn't stall. Idles nicely while I go fetch the trailer.
This was two days ago.
Tonight, I go out and it's a whole different story. As soon as it wants to get up on plane, stalls. I hear a bit of a rattle too, a little knock just before it stalls. 7 times I had to restart to make it to my river lot dock. The temperature has been getting up to 170 or 180 but no more. The manifolds are warm but I can hold them. They are almost hot.
A puff of smoke seems to be coming from the air filter after it stalls.
I get a squeal from my pulley ( probably the water circulator pulley ).
When I get it back in Neutral and start it, it sounds fine, no knocks or pings.
If it isn't something with the gas or carb. The gas could be a bit old and have some water in it? Then .....
I am thinking, yes, this Marine Cam might have been a must. Perhaps my mechanic doesn't know of this issue.
It might need the extra HP to pull off the job of pushing this heavy boat around. If it doesn't have the umph, maybe it is natural for it to stall. Just like me, if I try to do something and am tired, I am less able to do it because I don't have the energy?
So, if it is a cam issue, I imagine the engine will be torn down again and cams are probably quite expensive?
Is there a way I could just get this boat to run slow the way it is? I really only need to putter over to the swimming area and the travel on the river is only a maximum of 10 miles from one end to another.
I am going to try some Hi Octane and some dry gas and Sta-bil in the tank and see if it helps but I don't want to burn up another engine.
So I do appreciate these replies. I am not swearing by my mechanic and I am not saying he is right.
Help.
Here's my fixed engine. yeah, fixed alright. I will be calling him in the morning to see what he says about the stalling.
