Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
1988 omc cobra 3.0 liter 4 cylinder. Auto Choke Question.
  • 1988 omc cobra 3.0 liter 4 cylinder. Auto Choke Question.
    This engine runs good but is hard to start on a cold morning. It has an automatic choke. I need suggestions on adjusting it or whatever will get it fired up in the chill here in the Great Lake State (Michigan).
    It cranks like it is not getting enough fuel.
    Re: 1988 omc cobra 3.0 liter 4 cylinder. Auto Choke Question.
    Ayuh,... Do you advance the throttle to WOT, once to Set the choke,..??
    Do you pump the throttle at all,..??
    • #3
      I have not done that. So we should advance the throttle handle to wide open then return it to neutral and the choke will be set. Also the carb can be pumped by pumping the trottle a couple times?
      • #4
        Ayuh,... Generally speakin',... on a Carbed motor...
        Cold start,...
        I go Wot, then about 1/4 to 1/2, til she Lights, then pull back to a Hi-Idle, say, 1000 rpms...
        Warm start, I go to 1/4, to 1/2, then hit the key...
        • #5
          With this four winds it will not crank unless it is in neutral. I have a bass boat with 150 hp merc that I can keep in neutral and advance the throttle 1/4 and it fires up. But with the four winds the throttle is straight up or it wount crank.
          • #6
            Ayuh,... It SHOULD have a By-pass built in...
            Pull out on the handle, or push in on a button, or Somethin'.....
            Never seen a controller without it...
            • #7
              I am sure you are correct on the by pass. I will figure it out. Thanks. I have puttered with about 100 boats since joining the forum and could not have done the things I've done without you folks.
              • #8
                Should pull out if it is factory... Copy of the owners manual just in case http://www.fourwinns.com/past_product/owners_manuals
                sigpic
                87 Four Winns 170 Horizon 4.3 OMC COBRA"Only Child"
                only thing GM I own.. Of course it's the only one that gives trouble..
                2004 Ford STX 4x4.
                2011 Candy Apple Ford Mustang GT
                Hope all you want.. It won't get it fixed..
                • #9
                  Thanks, appreciate all the help.
