Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
OMC STERN DRIVE DISASSEMBLY
  • OMC STERN DRIVE DISASSEMBLY
    I HAVE A 1986 3.0 LTR OMC COBRA I/O ON A 1986 FOURWINNS 160 FREEDOM. I HAVE A CLUNK IN THE DRIVETHIS ONLY HAPPENS SPORADICALLY. I HAVE BEEN ON THE FUNKOPOLIS SITE BUT I CAN'T FIND OUT HOW TO DROP THE BOTTOM END ON THE DRIVE. ANY HINTS - IS THIS SOMETHING I SHOULD BE DOING ?
    Re: OMC STERN DRIVE DISASSEMBLY
    But Seriously....Welcome to the board
    • #3
      Well the first thing you should be doing is finding a marine mechanic who knows OMC Cobras, fixing that is not a DIY project
      1988 Four Winns 200 Horizon
      4.3 OMC Cobra
      98 Jeep Grand Cherokee 4.0 Selectrac
      07 Jeep Grand Cherokee Limited 5.7 Quadradrive II
      "While air doesn't freeze....rust never sleeps"
      • #4
        Thanks for the quick responses. I am on my way to a mechanic now.Caps lock is a habit I am trying to quit.
        • #5
          The other thing that you should do is get an OMC shop manual, they are still available from Evinrude/Johnson dealers and are very detailed, they explain all the systems of the engine and sterndrive.Just make sure the mech knows OMCs, what works on a Merc does not work on them.For example when changing the gear oil you drain from the bottom but but you don't fill from the bottom, you fill from the hole near the caviation plate. Doing it like on a Merc (bottom) does not put in enough gear oil and you would ruin the upper gears right away.The manual details all this stuff nicely.
          4.3 OMC Cobra
          • #6
            Thanks Lou, the mechanic I took it to is highly recommended by fellow boaters. The manual is the next thing on my list.
            Back to Top
