Hello,
I have a 91 OMC Cobra outdrive that has a leak of approx 1 gallon every 4 minutes from the area of the transom plate. I have pulled the lower unit and found water in the U joint bellows. No rust, clean U joints, shaft bearing clean and free, bellows look like new with no cracks or tears. I suspect the large pivot housing gasket may have been bad but not sure. I am replacing the gasket, the 2 yoke shaft o rings, the water passage seal and the shift bellcrank o ring. I have had no water in the engine oil.
Can water in the bellows leak into the bilge at high volume? I do not see how. I have read on this forum of some outdrives have a "weep hole" above the shaft bearing but do not see that feature on this model. Perhaps my transom seal is bad and I am dreaming of an easy fix. If the transom seal was bad I do not understand how water would get into the U joint bellows.
Any help or comments will be GREATLY appreciated. Thank you, Ed
