I recently bought my first boat and was given a hand written note from the previous owner on how to start the boat. Unfortunately I did not speak to the previous owner as I bought the boat from the dealer and the dealer had given me all the previous paperwork for the boat.
I hope someone here can help explain the bullet items in more detail.
Note that the boat came with an OMC 4.3L Cobra engine and a Morse Marine Products side mount control (Model # MNS-S & MNS-D) <at least thats the manual I was given with the boat> this particular control is available in pdf form on http://www.teleflexmarine.com/library/A4pics/IS-SM MN Controls.pdf
So the note to start the engine when cold states :
A. On Trailer
1. Plug boat hole
2. Disconnect Trailer lights
B. At Dock
1. Turn on bilge blower 4 minutes
2. Trim motor down
With Key off
3. Prime Gas
if cold Neutral D position
(4 times) full throttle H position
4. With control handle in H position
* Disengaged full throttle
Turn key to START
5. Release key to ON position
6. Return Control handle to neutral engaged
then forward or reverse to go.
A. On Trailer
1. Plug boat hole
B. At Dock
2. Trim motor down
With Key off
3. Prime Gas
Turn key to START
