Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Replacing Bellows on OMC Cobra Outdrive
  • Replacing Bellows on OMC Cobra Outdrive
    I have a OMC Cobra Outdrive model 987346. I need to replace both the u-joint and exhaust bellows. After pulling the stern drive unit can I replace these bellows without having to remove the pivot housing?
    Re: Replacing Bellows on OMC Cobra Outdrive
    Yes. Remove the exhaust bellows. remove the clamp from the transom shield side of the bellows, and release the bellows out of the bellhousing. It should pull out the bottom. If not, remove that big plastic nut and push the fitting out of the bellhousing for a bit more room.
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      Thanks, I will give it a try.
      Back to Top
