thomasjpierce21
- Jun 9, 2008
- 17
I recently installed a new shift cable in my 1989 Donzi with an OMC Cobra stern drive. I followed all the instructions in Stuart's fabulous directions that I found on this forum.
In the directions the OMC maintenance guide said that the distance between the end of the cable crimp and the shift cable guide eyelet needs to be 7 5/8" (+/- 1/32").
Does this mean from the end of the crimp on the cable side or from where the threads start with the barrel trunion?
The problem is I can't seem to find the happy medium between the transom shift cable engaging the clutch dog fully and the remote shift cable keeping the ESA switch in the correct position.
The shift pin in the upper housing is set to the correct height, etc and I followed the insructions to a "T"
Ultimately the problem is that when the ESA switch is working correctly the clutch doesn't fully engage leading me to believe the shift cable is the wrong length.
Can anyone shed some light on this?
