Re: 93 omc 7.4l king cobra impeller replace?
Hi Guys,
I have a 1994 chirs Craft Crowne 282 with a new BB Chevy engine and a rebuilt OMC King Cobra cone-clutch outdrive.
New to boating and haven't had the boat out all that much this summer. Last week I took the boat out after about 2-3 weeks of sitting there and it immediately started to overheat and was also very sluggish in the water. I took it back to the slip. There is no thermostat so I finally realized it was probably all the barnacles which grew on the outdrive restricting water flow to the impeller. Does this sound right? Any way I can check this with the boat in the water, or do I have to haul it out? I was planning on hauling it anyway to get the outdrive powerwashed, however I might have to tow it since I dont want to overheat again.
Also, it was very sluggish last time and could not get on plane before it overheated. I am afraid that the time before last, there was already restricted water flow due to barnacle growth and I tore through the impeller with out knowing it. Is there anything else I should be looking for to replace if I haul it out? Any tips would be appreciated.
thanks
