Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
OMC Cobra shift cable replacement
  • OMC Cobra shift cable replacement
    Twin 4.3 OMC with cobra drives
    I broke the shift cable which engages reverse and forward between the motor and the out drive on the port motor.
    Removed the out drive and discovered the outer sheath right at the brass slider where the shift cable guide slides on was broken.
    Unscrewed the brass slider and left the broken cable in place and am hoping that I can use it to pull the new cable through.
    I now have the complete assy. on order I hope to replace it next W/e so any advice would be appreciated.
    I have all the dimensions required but am concerned as to how?? and if I can feed the new assy through the rubber hose ????
    Any advice would be appreciated.
    Re: OMC Cobra shift cable replacement
    There are a lot of critical dimensions that are involved in replacing the cable. The easiest part is feeding it through. Make sure you at least have the manual and set it up correctly otherwise it won't work properly and you might even end up trashing the drive.
    • #3
      forget the idea of using the old cable for a guide because there is a seal and retaining ring (nyon tie) at the upper boot, it will not allow you to just pull the cable sheath out, you'll have to get in there behind the engine and remove the seal, do it right.
      '90 Chaparral 2000SL
      5.8 Cobra
      '67 MFG Westfield Regal
      80hp V-4
      (No private messages)
      • #4
        I really hope you have the factory service manual.Those adjustments must be perfect on both ends of the cable.Follow it to the letter.
        1981 ChrisCraft 210 Scorpion K,175 Johnson SeaHorse
        • #5
          I am almost certain that on Cobras the OD needs to be removed to replace the cable. I am however positive that you will not be able to pull the old one through the way you hope to.
          • #6
            YES! The drive must be removed....The ONLY way it will work.
            PLEASE get a factory service manual!
            2 YEAR OLD THREAD.....I HOPE HE HAS IT FIXED BY NOW!
