Re: Needed: OMC transom-seal 1966 square type
Yes, the part# for the full kit is 381105, including the clamp, the plates and the screws. The part# for the seal only is 310975.
Your idea about using the newer rounded-corner seal sounds good, but I've been unable to find the measurements of that seal to know if it would actually cover the existing hole. The existing hole on my transom does have slightly rounded corners, so if the newer seal is a bit larger, it may very well cover the hole ok.
I'll see if I can get a parts dealer to give me the measurements of the newer seal. The older seal that I have now measures about 18.25" high by 17.5" wide.
Thanks for the suggestion.
DHPMARINE said:
Sorry,seems I ran out of room.
And if the overall size is larger than the transom hole,who cares ?
It will still seal what you need sealed. (yes buy or fabricate a new transom seal plate for the outside.)
DHP
