Hey wanted to see if anybody could give me some insight. I am replacing my 4.3l omc, I found another 4.3l omc donor engine the difference is mine in a '92 raw water cooled and the one I found is '95 vortec fresh water half system. My questions are:
Would I be able to hook up the half system instead of using the raw?
If I am able to use the half system, which water pump should I use? Mine has the impeller in the outdrive but the '95 uses a belt driven water pump.
Thanks
Thanks
