Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
OMC Gearcase Questions
  • OMC Gearcase Questions
    Boat title says it is a 1978 Mark Twain. On the gearcase it just says OMC Sterndrive (no 400 or 800) with a 235hp on a sticker below that. According to the Clymer's Shop Manual that I have, the 235hp set up was for 1977 models. Tag on the gearcase says Model# 983489 - Serial# J351978. So does this make it a Electromatic gearcase? The change happened between 77 & 78 so I want to make sure. If so can I use Lucas 80-90W high performance gear oil?
    I think '77 was the last year for the 235HP. But the model number would be on the engine tag - typically on the starboard side somewhere around the rear motor mount. The number should read something similar to 990240E 1977.
    Yes, yours would be an electric shift. Lower gear case needs to be Type C lube. Upper gear case can be any that you like. The lower needs a thinner lube otherwise the shifting doesn't work quite right.
    [ATTACH=CONFIG]temp_270443_1499813187632_202[/ATTACH]
    • #3
      Take a picture of your drive and post it.
      1998 Wellcraft Eclipse 24 Cuddy
      Volvo Penta Duo-Prop 7.4L "LK"
      2006 Sun Tracker Party Barge 21
      Mercury 90 4-Stroke FI
      "Common sense is not very common"
      "Failing to prepare is preparing to fail." -- John Wooden
      • #4
        throw the clymer manual away (they are filled with incorrect information and are best used as knee pads) get a factory manual
        most boat manufacturers used motor/drive combinations until they ran out of stock. this may be 2 or 3 years after OMG stopped producing
        1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - http://forums.iboats.com/forum/owner...988-rogue-2420
        Past Boats
        1970 Wooster Hellion - Merc 9.8
        2002 SeaRay 190BR - 5.0 - A1G2 - "Cheasheads in Paradise"
        1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
        What’s behind you doesn’t matter.Enzo Ferrari
        • #5
          990241G is what I have pulled from something.
          • #6
            Where does one find a factory manual for this old girl?
            • #7
              the manuals are ordered thru ken cook company (original publisher for OMC) or you find a used on on ebay.
              https://www.outboardbooks.com/brand/OMC/
              There are 4 lists for 1977 235hp, all of them have the same manuals listed
              https://www.outboardbooks.com/manual/990241G/OMC/
              https://www.outboardbooks.com/manual/990240E/OMC/
              https://www.outboardbooks.com/manual/990240G/OMC/
              https://www.outboardbooks.com/manual/990241E/OMC/
              Past Boats
              • #8
                That's it. 1977 235HP Electric Shift with Select trim.
                • #9
                  Thanks for the link.
