Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
worn bearing carrier repair (yoke shaft). knurl and/or Loctite sleeve retainer?
  • worn bearing carrier repair (yoke shaft). knurl and/or Loctite sleeve retainer?
    Hi guys - busy pressing in gears and bearings today.. noticed bearing carrier was a little loose when race was installed (this is the horizontal yoke shaft).. any tips on repairs? I know the bearing preload isnt all that much.. will a knurl and loctite work, only loctite?
    tx
    Im referring to the loctite sleeve retainer which seem sis made specifically for this..
    another option is the loctite liquid steel (aluminum filler option)
    Could be anything NOT KNOWING WHAT your working on.
    NO PERSONAL QUESTIONS, THIS IS WHAT THE FORUM IS FOR.
    • #3
      my bad - its the upper gear housing omc cobra - the carrier where yoke seal sits.. apologies
      • #4
        depends on amount of damage. if a fair amount of slop, machine the housing press in sleeve, machine sleeve to proper bore
        1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - http://forums.iboats.com/forum/owner...988-rogue-2420
        Past Boats
        1970 Wooster Hellion - Merc 9.8
        2002 SeaRay 190BR - 5.0 - A1G2 - "Cheasheads in Paradise"
        1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
        What’s behind you doesn’t matter.Enzo Ferrari
        • #5
          its not super loose.. just not firm - i think i shd not knurl but just loctite 620/permatex sleeve repair it- knurling is better on steel but aluminum i think will just invite issues down the road possibly..
