1988 Four Winns Horizon
502APRGDP
1988 OMC (GM) V8 5.0L
The Seloc manual notes "Use Silicone Rubber Sealer at all water passages and wherever a seal butts against a gasket."
Should the Silicone Rubber Sealer be applied to both the Cylinder Head mating surface and the Intake Manifold mating surface - below Intake Manifold gasket before setting gasket on Cylinder Head and on top of gasket before setting Intake Manifold on top?
How much Rubber Sealer should I use at the water passages? About 1/16" thick? More? Less?
I plan to use the preformed Rubber seals that came with the intake manifold gaskets - at the fore and aft China wall edges. How much Rubber Sealer should I use below and on top of these preformed seals?
Thanks
502APRGDP
Thanks
