Biggvs_Richardvs
- Sep 3, 2017
- 12
Hello,
My name is Rich and I'm up here in BC with an '89 SeaRay with an OMC Cobra 4.3 in it.
I have a leak.
It only leaks with the engine running, and I have traced the leak down to the little wide U-shaped are just below the Exhaust T and above the transom plate.
Has anyone else seen that before and can maybe suggest a likely cause? Both bellows look to be in pretty good shape. If it was the shifter cable, I wouldn't expect it to only happen with the engine running, plus I still get the leak out of water and with a hose hooked up.
Here's a quick 1 minute video of the leak:
https://youtu.be/TNht3Fq_SvU
Sorry the camera is sideways, but its a really tight space.
Any help/advice greatly appreciated
I have a leak.
