contactdewitt
- Feb 15, 2017
- 15
I have a 77 Orrion ski boat with a 351 ford motor. the model is a standard 235 HP. while I was fixing an electrical problem I managed to overload the starter on the motor and when bench tested it failed the no load test. No big issue here but I inspected the fly wheel and sure enough it has a few damaged teeth. I am loking at the best way to get to the flywheel to replace it. My guess would be to remove the out drive unit as a whole from the intermediate housing this should get me to the flywheel? The other thing is can you get an aftermarket automotive flywheel or is mine a proprietary part for OMC? This question also goes for the starter motor though I know it needs to turn CCW.
