Hi I just recently bought a 1978 Starcraft Holiday 18.
I had it on its first try out getting used to controls etc when I ran out of gas... until this point the engine had started first time and seemed to be running smooth.
Now it will turn over. It not fire up. Yep put gas in, also noticed a small clear bowl stating if full of fuel change pump, this is empty. I've also pulled the line going into the carb and this has fuel in it
Any thoughts advice on what's wrong
