1969 omc sportsman 120
osborne looney
i need some help on identifiying engine -- looking for ign cap/rotor / points / cond - and wire set --tough to find a-lot of info on this
found tag on engine cuer69mb or cufr69mb -- also OMC 3195983--4cyl - dual carbs
kenny nunez
Convert your engine to a Petronics electronic kit. It will start easier and run smoother. Most of the current ignition parts are not the quality of the 60s & 70s and not very reliable.
osborne looney
if i knew what engine was in it i would !!!!! thats one reason i listed this post
Ayuh,.... As far as I know, only the 2.5l, 120 hp motor ever used the twin carb set-up,....
southkogs
'69 OMC 120 should be a 153 Chevy II engine. Model number on the engine should be something like "CUFM-69M"
