yes water running but not very long at that start. I had started the engine warmed it up set up the timing 3* btdc to burn regular gas , adjusted the Holley 4010 to 1 1/4 turns per side running about 16-18 vacuum earlier with no problems at start. I will say that I did had an unusual black substance floating in the water before this as the engine was running that bothered me a little. We were about to re start and hook up the Tac when I hit the the button and had a fire in one or two revolutions of the engine.
