Hey Everyone,
I have a 1989 Four Winns 200 Horizon 5.8 liter V8 w/OMC Cobra. The boat has been in the family since day 1, but used very little... Has 40 hours on it!!! Engine bay looks mint!
Anyhow, I took possession of it last season, took it to a mechanic to have it checked out. He gave it a tune-up, serviced the drive, adjusted/inspected everything and it was good to go. Took it out last season and it seemed to be fine, but low on power. Throughout the day, it got worse. I had 7 people, but that boat should handle that fine as it always has in the past. By end of day, boat was not even able to plane. Started/idled/ran very smoothly otherwise, just wouldn't rev out. Seemed like a fuel starvation issue.
I've pulled the fuel attachment at the carb and checked the screen - all clear. Pulled a plug, and while they are old, no corrosion. Wires also old but seemed fine and correctly placed. Again, I think this is fuel related. It was on a fresh tank when the issue started.
I'm mechanically inclined and tune my own cars, but boats are not my specialty.
Anywhere you guys suggest looking first? Any 'easy' stuff to check before I take it in to the mechanic? I traced the fuel line from the holley carb (carb looked clean as new) back to some module, which I didn't even know what it was... a pressure regulator of some sort? Any tips would help greatly.
