Hi guys,
I am working on a 93 OMC 5.8 carbureted engine. Engine model number: 584APRAMK. I was trying to get the alternator belt to stop squealing. I found a new belt and had to loosen all nuts to get it installed. In the process, I now have NO SPARK.
I used a test light to see if I had power at the positive wire on the coil (the purple wire). No power/light. The engine will try to turn over, acts like the kill switch line was pulled. Replaced the kill switch to see if that was the issue. No change. The wires leading to and away from the kill switch are "hot" to the touch after turning the key.
While examining the engine, it looked like there was a nut on the alternator touching the valve cover. I have protected that area. At one point, I noticed the purple wire was broken off the "S" post on the back of the alternator. It has been reattached.
This happened once before about 3 years ago. The mechanic said it was the rear interrupt switch. Last year, replacing the kill switch fixed it. I have purchased the SELCO manual for OMC Stern Drives but am unable to find any help.
Any help I can get will be greatly appreciated.
