dangerroth
- Jun 21, 2017
- 1
Can someone please help me with this nagging issue!?!?
I have a 1995 Four Winns Vista with twin Cobra OMC 5.0L V8 fuel injection. The issue started five years ago. The boat planes at 3200RPM but periodically the port engine will drop down to 2000RPM and bounce between 2000RPM and 2500RPM. The sound has been described by one mechanic as "bouncing off the limiter." The issue happens in both forward and neutral. When the issue started it would happen maybe once every two hours of use. Over time the intervals shortened to once every five minuets so I took it to a mechanic. This was three years ago. The mechanic convinced me that it was an engine issue and the engine needed to be rebuilt. I bit the bullet and had the engine rebuilt with a one year warranty. The boat ran great all of 2015 but didn't get used much. At the start of 2016, just over one year after the rebuild, the issue started happening again. Towards the end of last year it was happening almost constantly. Now it's the start of a new season and this is keeping me from using the boat. I have replaced the fuel filters, fuel pump, and had the throttle position sensor replaced. It was hooked up to a computer last year and didn't show any error codes. The starboard engine runs fine. The port engine sounds great when it starts up and runs fine at low RPM. I had a independent mechanic look at it last week and he suggested replacing the shifting cable. He said the "shifting cable is hanging up" but my normal mechanic is skeptical that will fix anything. No one can tell me what the heck is going on! There are links below to some videos I took that show the problem. We keep the boat at a marina in Toledo, OH and store at the marina in winter. We don't have a trailer so there are very limited options for mechanics on the water. Any help would be greatly appreciated!
https://www.youtube.com/watch?v=LnSUtRJhIHQ
https://www.youtube.com/watch?v=wfCXNOOl3Us
https://www.youtube.com/watch?v=TVLFXOwWzqE
https://www.youtube.com/watch?v=YUwS7ImQanM
