Extremes31
- Jun 27, 2015
- 5
I picked up a 1985 Sean sprite with a mercruiser 140 , I got it cheap ,starts and runs great for like 45 minutes then it's begins to bog and hesitate . The guy I got it from said he thinks it had water in the gas .I tried to remove pick up tube took off the first fitting . I could tell the guy stripped it , I actually think he put a larger size in because the threads are screwed now . The elbow turns right and left only like a half inch . Then tightens up either way I turn it . Afraid to turn it further I don't want to snap it off . So I took off the sending unit to see inside if the pick up tube it turning with the elbow . I noticed a really small screw in the tank laying next the the pickup tube "I did not drop " fuel looks very clean except that could this be my issue or should I drain it all ?no screen on tube except on the elbow . Do you think the suction would pull that screw to the top of the elbow where the screen is? Tried magnet can't get it out lol may have to drain it anyways
