ab59
Ensign
- May 10, 2017
- 979
I am changing out 5.7 engines . I have a Cobra out drive . When I took the jewelry off the blown engine for removal I did not remove the shift cable set up from the bracket instead leaving it all in one piece. I did have to remove the throttle cable for removal. I am using the same intake manifold on the new engine so everything should be the same for re-installing the new engine. Will I have to worry about shift cable adjustment since I left everything in the bracket ?? i am hoping that I can just bolt the bracket down and be ready to go.
The throttle cable is another question because I am going back with a different Holley carb that has some differences that are going to take a little re-engineering .
thanks--ab
thanks--ab
