yannickevenas
- Aug 10, 2009
- 15
Hello,
Several years ago a mechanic charged me to replace the shift cable while the boat was in the water.
I just read some posts there, and it looks like the only way to replace the cable is to take the outdrive out, am I correct?
Also, I just discovered there is a cable adjustment tool. Does the drive absolutely has to be pulled out in order to adjust the length of the cable on the engine side with the tool ?
