stancalame
- May 10, 2014
- 113
Out on lake yesterday and was trimming motor up going through shallow water while turning at about 3,000 RPM. Could not get lower unit to trim back down. No Click, no sound at all. Trim up works fine. I did some reading and found this great trouble shooting guide. it says "No Trim-Out/Tilt-Up, Motor Does Not Run
16-13-14-15"
First step is test switch but dont know how. I have attached pics of my trim motor and throttle handle. From what I have red, blue wiire goes one direction and greeen goes the other. I also have a red wire. I have a Model 87 Fluke meter and can easilty test continuity just need some guidane. From what I can tell I have three wires from throttle handle/switch that come to a term strip blue,green,red. That term strip also has larger gauge blue and green wore going into motor. I assume the term block includes some sort of solenoids.
Where to I put my red meter lead and where do I put my black meter lead. I tried black meter lead to engine ground and red to both of the blue and green wires. . I dont think I did it correctly because didnt get continuity. I know the up side of the switch works.
Second step is check for blown fuse/ circuit breaker. There sems to be one on trim motor. I pushed it and nothing happed. I didnt feel anything when I pushed it.
Third Step Bench test motor - Not sure how. I've read I should put hot battery wire to blue and green wires. Doesnt a ground need to be connected somewhere? IF so please elaborate.
Forth Step is relay control box malfunction. Not sure I have one and if I dont I dont know what it looks like or where to find it.
16-13-14-15"
