Gunsanddaisys
- Apr 26, 2017
- 15
It's about time I make a post instead of just lurking around.
I'm working on getting my family's 77 cobalt bow rider back into shape and I'm currently at a bit of an impasse. The motor is a 351w based 235 with selectrim. It's idle seems perfect sitting at about 575 rpm from what the tach tells me. The problem arises when trying to throttle up. Once it reaches an indicated 1500ish rpm, the motor hits a hard cliff and starts to die until the throttle is backed off. If the throttle is moved quickly, it backfires through the carb, but can be returned to an idle if back off quick enough. I'm leaning towards it being carb based since it sounds like the secondaries are opening when it hesitates. Any help would be appreciated.
