As far as the hp limits for the Cobra drives the standard Cobra is fine with the normal small block V8s. With a big block I think it's the same issue as the Alpha drive. This is why OMC used the Daddy King (cone clutch) drive with the GM 454.
When I had mine, I was a frequent visitor to Offshore Only and other forums where there was a rather large OMC King Cobra (and Four Winns Liberator) following.
There was a guy on Offshoreonly that had a 211 Lib like mine that had built that 460 to the point where it would "Bury the Speedometer at over 80mph" (his words!) at WOT!
Most of them indicated that the King "Dog" and coupler would withstand the extra HP.with no problems The 454 was never offered in front of the King Dog either..........
The downside was the 211 hull gets VERY scary at high speeds.
i just did the oil on my 89 sundowner 225 i took all the plugs out ran mineral spirits through the drive to wash out all contaminants then refilled the drive from the top port put 32 oz of Lucas oil stabilizer in it and 32 oz of 75/90 in it did it over a 3 day period just cut the tips off the bottles and let them feed themselves into the drive
Looks like we can turn any thread into an oil thread!!
Well, good luck on that. Most of us here would suggest that you're doing 2 things that could damage or destroy your drive.
NO drive manufacturer suggests adding any type of snake oil to drive lubricant. Lucas doesn't show any sort of ASTM testing that would indicate how their product works when used in a high load hypoid gear application nor a marine application.
(No "Marine Drive Oil specification exists by the way...
https://www.nmma.org/certification/oil/ )
Filling your drive the way you did may work but it took you 3 days to fill it!! The rest of us would simply pump it in through the OMC recommended "Fill" port (Which takes minutes not days......)
I had a look at the Lucas site for specifications of their "Stabilizer" snake oil.
There was no indication of the standard ASTM tests for gear lubricants. I would want to see as a minimum (among others) the FALEX Continuous Test ASTM D3233 which tests lubrication capability with a 10% water contamination.
Most ALL registered hypoid gear lubricants meet or exceed this test (and others)
If you love the following Lucas Snake oil test.... put 10% water in it and see what happens.
https://www.youtube.com/watch?v=wLnpHWwu9xM
Although I am not a big AM$OIL fanboy, they at least list the ASTM tests their oils meet/exceed.
My suggestion for that anyone with an OMC/Volvo/Mercruser drive, use a good SAE (registered) synthetic (or NON synthetic) gear lubricant and stay away from the Testimonial Supported (snake-oil) additives.
YMMV,
Rick
