Mercybenz63
- Mar 6, 2017
- 13
Total noob here...to boat ownership and OMC.
I had been watching this boat drop in price on craigslist all of last fall. The boat had attractive lines and a decent story.
After watching all fall, I saw it pop up on a boat donation sight on ebay a few days before Christmas. After briefly consulting with the wife I tossed in a throw away bid for $250.00.
Lo an behold, I was the lucky winner, $227.50!
And what did I buy? A 1976 Crestliner 995 Crusader with an electric shift OMC stringer 235 (351 Windsor).
The PO told me it had a bad starter and popped freeze plugs...Ouch! But otherwise thought it to be a viable vessel.
Well, after getting it unstuck from the frozen Iowa field and dragging it home on the 1986 EZ Loader roller trailer...with rotted tires...I set it to defrost in my father's garage.
Inspection revealed; an indicated 307 hours on the motor, solid stringers, transom and fiberglass, vinyl in decent shape, popped freeze plugs (behind the motor mounts, cracked exhaust log on the LH bank, bad starter, rotted transom seal.
Over the winter I set to work, pulling everything out that came out easy to get access to the motor. I purchased a new starter and freeze plug kit. My hope was to determine if the boat would run before getting more money into it than I could sell the trailer for (at least that is what I told my wife.)
Dried it out, replaced the starter, ground out the crack on the exhaust log and JB welded and popped on a new gasket, got real familiar with the tilty system on the stringer when I removed it all to replace the freeze plugs. (I discovered that the tilt motor works but the switch/solenoids may be bad as the switch does nothing in the course of bleeding the system out during reassembly.) Replaced transom seal.
Spring approaching...excitement building.
Attempt to turn over the motor...it turns but does not fire, sound healthy though! Still worried about horribly cracked block and waste of $500. Diagnose no spark condition as failed condenser (yes, really...I know.)
After all that, hooked it to the hose (finally warm enough here in the frozen plains), set the gap on the points, and turned the key. It fired immediately and settled into a healthy idle! Huzzah! is this even possible!?!? Revving fine, and the litmus test for the e-drive...put in gear...click...prop spinning!!!!
Wow! So excited now!!! Cannot wait to get this thing on the water. Took the day off early Monday to register the boat, fill 'er up, and take it out. Perfect sunny weather, boat ramp all to myself. Trailered boat in the water, no filling with water. Push it off the trailer, it floats!! Dreams really do come true.
Start it up, and throw her in reverse. Whoa! this thing is powerful! Boat runs great up and down the river, but running a little hotter than I would like especially after idling through the no wake zone, up to 220. Better get it back on the trailer before things go from good to bad.
Hmmm...no experience pulling up on a roller trailer in a super powerful boat in a cross current. Stern tends to drift crooked on approach. Forward, damn crooked. Backward, forward...damn crooked. Backward, forward, backward, forward, backward...frustration...forward...jammy, beads of sweat, forward, backward....for...nothing...nothing...nothing!
Aack! I must have bodged the super sensitive crazy spring I have been reading about. YOU IDIOT! Break the damn thing on the first outing...MORON!
Well, I finally manually get it up on the trailer and pull it put of the water...dejected, loser. What a waste of work.
Walk around back to strap it down and...no prop? Wait, what happened to the prop?
Questions for the group...can the prop just fall off after being abused trying to get on the trailer (obviously yes, but how)?
What prop should I buy now that I am in the market 14x14,16,18,20? (I plan to use the boat recreationally to teach my kids how to ski and tube.)
What controls cooling, the impeller in the stern drive unit or the water pump looking thing on the motor?
Am I crazy to keep putting money in this thing?
Thanks for all the great info I have gleaned from your experts so far iBoats. Truly a great bunch of boater folks!
