I have a 73 seaswirl that I'm fixing up. I replaced the tilt motor and it has been working fine. I have lifted and lowered the out drive maybe a dozen times total since the replacement. Yesterday I go to lift the outdrive and it only went up a couple inches and stopped. I then manually lifted with light pressure on the out drive while engaging the tilt motor and it would go up. I checked my almost brand new marine battery voltage and it read 12.55v. To me It seems like the motor isn't getting enough juice to it? Any ideas on what i'm looking for?
I should add that I have bypassed all of the solenoids and was touching the lift wire directly to the positive battery terminal.
